ignition service
Old Feb 18, 2005 | 02:41 PM
polarisman3's Avatar
Default ignition service
well the dealer called and left a message about some ingnition problem that they have to fix...takes 1/2hr...is this just the spark plug wire that rubs between the frame and gas take??? didnt say what machine it was for 03 sp 600 or 04.5 sp 500 (the 2 i have bought from him and still own)...cus if it is just that then i aint bringing it in...ok thanks...
Old Feb 18, 2005 | 09:25 PM
jeffro206's Avatar
polarisman3, its the 500, the plug wire can get caught between the brake junction block and the tank causing it to short out. if the wire is damaged they are replacing the coil. its up to you to have it fixed, but the last thing i would want is to be out somewhere and it short out or worse yet going up a long steep hill and it decide to short and quit. a simple fix could prevent worse problems.
Old Feb 18, 2005 | 11:11 PM
ok thanks jeffro206 i will check it out my self then....thanks
ultangler
Nov 30, 2024 01:35 AM
EIF
Apr 20, 2017 07:15 PM
kbazzy
Sep 26, 2015 11:26 AM
Sw00p
Sep 24, 2015 02:50 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
