which carb for SP 700
Old Mar 23, 2005 | 01:23 PM
SPORTSMAN70003's Avatar
Default which carb for SP 700
Not for sure what offset you need with the Maxxis 5 spoke wheels. I looked them up it and it says +15 offset and I don't know what that means. With the 27" tires you will have rubbing you would need a lift or you can do as I did and put spring spacers under your springs. The wheels you get will need a little offset if you go with a 9" or 10" wide tire to keep them from rubbing the tierod ends. I have some 27" Gators that are 10" wide on stock rims and I have to use a 1.5" spacer to keep them from rubbing the tierods. With the 27" tire you will lose some preformance that's why I got some 26" Mudlites on C-series type 6 wheels.
Old Mar 23, 2005 | 02:39 PM
M40A3nut762's Avatar
thanks alot, i think im clear now. im going to get a highlifter lift kit, and the maxxis wheels, both from highlifter. im not positive about tires yet, i might go with 28" zilla's, no matter what, im going to use racer spacers on the wheels.
cory
Old Mar 24, 2005 | 07:39 PM
firemedic5586's Avatar
I have the TMX carb that Aaen has out for the 700. Its a carb made for 2 strokes that they are selling for the 700. I had to do some tweaking to get it to run for me, set up via derections that came with it, the thing was way lean. Now it is gas hungry BIG TIME. Just ordered a '05 500HO carb with 4.7 miles on it coming from a local salvage yard, going to try that instead. Do some looking over @ Highlifter for info on the TMX. those of us who have ran it all can atest to the slight "bog" you get if you nail the gass hard on it. hope this can help.
GregM
Mar 6, 2018 06:53 AM
GregM
Jul 29, 2015 09:41 PM
ghost civic
Jul 27, 2015 03:15 AM
Aitch
Jul 21, 2015 09:40 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
