MY first Polaris 4x4
Old Mar 22, 2005 | 05:50 PM
DEARHUNTER's Avatar
Default MY FIRST 4X4
I am trying to get all the bugs out of my 1994 300 4x4. I started with this older model because I store it at my hunting cabin. So far i must of used 10 spark plugs. I had my oil injector set buy a local dealer.should i diconnect the line that feeds the oil? our should i let the oil run dry and premix my gas 40-1, we do not run the machine hard. Mabel to slow. what else can I look forward too. can anyone help this firstimer???? .....The Dearhunter
Old Mar 22, 2005 | 06:37 PM
xcrider's Avatar
I wouldn't assume that it is oil over pumping that is fouling your plugs. Have you checked the jets or how your choke is adjusted?
Old Mar 22, 2005 | 11:26 PM
20045SP500HO's Avatar
also make sure you have the right plug and you are running it long enough to get hot.
Old Mar 23, 2005 | 01:05 AM
elkbow's Avatar
also, if you want to premix, you usually have to do an injection block off for the existing setup.....
Old Mar 23, 2005 | 10:55 AM
DEARHUNTER's Avatar
Default MY first Polaris 4x4
Thanks for you reply. If I go with the blocked oil injector, where is it blocked before or after the pump, What do i block it with. As you can see I am new to this. Dearhunter
Old Mar 23, 2005 | 10:57 AM
DEARHUNTER's Avatar
I am useing the one rec. bu Polaris for this model.
Old Mar 23, 2005 | 10:58 AM
xcrider's Avatar
Deerhunter, are you sure that it is too much oil?
DEARHUNTER's Avatar
Where do you block it. With what??????
Old Mar 23, 2005 | 01:18 PM
BryceGTX's Avatar
Hey DEARHUNTER. If you are running slow, you are better off with oil injection because it reduces the oil at low speeds/thottle settings over pre-mix. Like xcrider says, are you sure it an oil problem? A sticking choke, or bad plunger in the choke could cause it to run too rich causeing the same problem. I would be inclined to check the carb first.
I hope this helps you
BryceGTX
Old Mar 23, 2005 | 01:19 PM
jimmypsp700's Avatar
you have to buy a block off kit from HSP, HPD or Aaen. I would leave the injection system and check the things others said.
welcome,
Jim
