What killed my battery?
Old Mar 24, 2005 | 11:15 AM
HELLHOUND's Avatar
Default What killed my battery?
Mine (04.5 sp500)had to be replaced 3 days after i got the quad same symptoms i think you got lucky and yours lasted awhile the new one seem to be gatting aweak think ill go after market now that the warranty is up
Old Mar 24, 2005 | 02:37 PM
Zbart1's Avatar
It was the Colonel in the dining room with the revolver [img]i/expressions/face-icon-small-wink.gif[/img] [img]i/expressions/face-icon-small-happy.gif[/img]
Old Mar 28, 2005 | 11:51 PM
Primus's Avatar
Just an update. After the incident I recharged the battery (out of bike at 2 amps for 6 hours) and brought to my dealer on Thursday 23. They let it sit all weekend and checked it today. Started right up, they load tested the battery and it was fine, charging system working perfect and they couldn't find anything wrong or drawing power. Just must have been one of those freak things. Like I said I plowed all winter using the winch constantly and never had a power problem starting in the severe cold, that's what puzzles me that it went dead now that it has gotten warm out. We'll just see if it does it again. Oh, and it is a black case battery not the white one, and I have the Warn 2.5ci as some of you have asked.
Also they drilled a hole in my Glacier mount plate so now it doesn't have to be removed to change the front diff oil.
Old Mar 29, 2005 | 12:19 AM
tyler711's Avatar
Glad to hear that your problem's all worked out.
How big is the hole they drilled? I had to take it off this weekend to change the fluid and it was not fun. I'm just a kid and I had trouble getting my fingers up there behind the radiator for the nuts. My grandfather has an old craftsman drill press I can use, I just need to find a bit that's big enough.
Old Mar 29, 2005 | 08:45 AM
  #15
scootergptx's Avatar
Supersock
Hired Gun!
Originally posted by: tyler711
It was the Colonel in the dining room with the revolver!
Sorry, immature.[img]i/expressions/face-icon-small-sad.gif[/img]
Video killed the radio star, and the battery was collateral damage.
[img]i/expressions/face-icon-small-tongue.gif[/img]
Old Mar 29, 2005 | 04:37 PM
  #16
garrett5462's Avatar
leaving the lights on for a while will do it.
Old Mar 29, 2005 | 09:04 PM
  #17
Primus's Avatar
Hey Tyler, I think you need a hole saw. I don't know what size it is exactly, as the dealer did it, but it is a good size, enough to put your socket through it and drop the drain bolt through.
Old Mar 29, 2005 | 09:07 PM
  #18
tyler711's Avatar
Alright, might have to take a run to the hardware store for that. Thanks
ty
Old Mar 29, 2005 | 10:53 PM
  #19
Treacherous's Avatar
What kind of build dates on these bad batteries? Mine hasn't ever given me a problem. I keep mine outside all the time and it has been down to about 0'F for a while during the winter.
Old Mar 30, 2005 | 12:37 AM
  #20
elkbow's Avatar
You know what you guys need....what I just installed on my KLR650....a battery gauge/indicator.....they are made for motorcycles, etc., they are small and work great and easy to connect (even though I put my through my relay/breaker panel)
here is a pic, lousy pic and the flash killed the lights on the gauge, but if you look at the reflection in the windshield above it you can see the lights:
battery power gauge
plus I have my finger prints all over it since i just installed it tonight....
dave
