Slow 2000 sp500
Old Sep 27, 2000 | 05:06 PM
Bill.Ciliberti's Avatar
One thing to do is to make sure your exaust is not pluged.There is a pipe towards the rear of the muffler that snorkles downward,make SURE that this pipe is clear.I had a problem recently with no power on the Xplorer.I installed newer clutch springs,new belts,carb adjustments ect,and none of it worked.
I happened[by accident] to notice that the exaust pipe had clogged with mud,it than hardened and closed off more than half of my exaust.I cleared this up,and man,does this baby move now.
Try this,[huge differance]
Change the primary spring on your front clutch to the green color one,your belt will hook-up like you've never seen it before.My Xplorer will now wheelie EFFORTLESSLY.Rick Ritter sells the springs for around 25 dollars,well spent money to.===Bill
Old Sep 27, 2000 | 06:43 PM
Cheetah's Avatar
Bill this sounds like a good setup, sorry but I don't know who or what Rick Ritter is. Is this a catalog or a mechanic you know? I would like to try it!!!
Old Sep 27, 2000 | 06:46 PM
JAnderson's Avatar
Greg,
I took a look at your pics. When you go submarining, can the exaust pipe be submerged without taking on water?
JA
Old Sep 27, 2000 | 08:58 PM
gregsims's Avatar
The engine exhaust is not an issue when submerging a quad. I see engine exhaust snorkels all the time and the people tell me they have done it because the quad dies in water. It does help keep mud out of the exhaust, but the reason most bikes die in deep water is the drain line on the carb.
I think you got two really good responses. Both I have seen personally. If you do get mud in your exhaust and do not clean it, you will have to rebuild the top end eventually as I have just done for a friend. Walexa is right about the belt. A worn belt will severely effect perfomance. Top end and take off.
(Look... I can just repeat what others have said and look like I know something) Ha!
Greg
Old Sep 28, 2000 | 12:34 AM
  #15
PolarisMan's Avatar
(cough)(cough)air(cough)fil(cou)ter(gh)
Old Sep 28, 2000 | 12:43 AM
  #16
BERT's Avatar
MUD IN EXHAUST WILL RUIN YOUR DAY.
BERT
Old Sep 28, 2000 | 02:03 AM
  #17
Cheetah,
You can contact RR at 1618-644-3211.He sells high performance parts for quads.He will spend as much time on the phone with you as you need.Tell him what you want out of your clutching,and he will recommend the correct color spring.
Best of luck,
Bill
Old Sep 28, 2000 | 01:28 PM
  #18
Cheetah's Avatar
My 2000 SP500 only has 250 miles on it so I don't think it's a belt problem already, air filter looks new!!
Old Sep 28, 2000 | 01:48 PM
  #19
Thor's Avatar
Is the timing on the Sportsman 500 adjustable?
Don't forget, you quad is still breaking in and will get faster with a few more miles. But... on the other hand, some are slower than others for some reason. Could be the timing/jets/mixture screw.
Gwolf228
Feb 18, 2017 01:36 AM
Dammar
Apr 20, 2016 06:03 AM
Scooter's Shop
Oct 9, 2015 02:09 PM
ReconBayou
Sep 23, 2015 02:41 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
