Need help adding speed to my 600!!!
Old Mar 27, 2005 | 11:16 PM
Polaris600's Avatar
Default Need help adding speed to my 600!!!
What is the best way to get a whole lot of power and speed out of my 04.5 spotsman 600. It ha about 724 miles on it, its completely stock(badlands tires), and it only goes 58mph. My 500 H.O. (also stock with heavier rawhide tires) beats it off the line and stays ahead forever. I was looking at rejetting it but would it help? Thanks...
Old Mar 27, 2005 | 11:23 PM
SPORTSMAN70003's Avatar
Depending on how much work you wanted to do but there are a few things you can do. Heel clicker clutch, exhaust, bigger carb,etc. Look at my sig below for all the mods I have done on my 700 that will give you an idea.
Old Mar 27, 2005 | 11:29 PM
2manytoys's Avatar
The 600 has plenty of power. You just need to tune the clutch. You can start with a primary spring and change your secondary spring position. This is a cheap mod with big results.
Pehter
Oct 3, 2024 11:00 PM
fredrikrosen
Sep 28, 2015 09:58 PM
2many2ride
Sep 27, 2015 04:35 AM
ReconBayou
Sep 23, 2015 02:41 PM
WilliamBos
Sep 22, 2015 04:07 PM
