oil leak-help
Old Mar 28, 2005 | 05:40 PM
6x6's Avatar
6x6
Default oil leak-help
have a sportsman 500 2003-ever since first oil change-cant get oil to stop leaking around drain plug on oil tank.anyone else have similiar problem and a fix?
Old Mar 28, 2005 | 06:32 PM
2manytoys's Avatar
There is supposed to be a gasket on the drain plug. If its not there then it will leak no matter how tight you get it. If you do have a gasket you might want to try a different kind of gasket.
Old Mar 28, 2005 | 06:35 PM
Bing's Avatar
Super Quad Patrol
Smokes meat all the time!
its a plastic washer that comes with the oil change kit
be sure it is grit free and clean and it should hold
Old Mar 28, 2005 | 06:40 PM
6x6's Avatar
6x6
i have installed the plastic washer and it still continues to leak.
Old Mar 28, 2005 | 07:07 PM
chuck1's Avatar
I would check to see if there was a gouge in the metal somewhere if that happened to me. Maybe the drain plug has a ding in it from dropping it on the ground or something. That could cause it to not seat right.
Old Mar 28, 2005 | 08:00 PM
Bing's Avatar
Super Quad Patrol
dont be scared to use a little rtv on the underside of the bolt head either
if it still leaks,,,,clean it really good and be sure its not leaking where the metal meats the plastic tank
Old Mar 28, 2005 | 11:40 PM
fishslab's Avatar
Try thread tape on the bolt. If it still continues, it may have a crack in the threads on the tank.
