Crank Bearing Spacers...
Hi guys, been looking at a friends crankshaft recently whilst my engine is in pieces too, and I noticed that one of the "crank pin spacers" (the washers that go either side of the big end bearing) The engine was running pretty much fine, but we were just checking everything out and putting a new piston in.
As a result, the clearance to the crankshaft is well outside the specs but the bottom end bearing seems fine.
What will happen running the engine without this spacer? (it's a 400 2-stroke).
It's only for light farmyard use so won't be revved hard or raced... we both wish we'd never decided to put a new piston in now, as ignorance is bliss!
POLARISUK if the shimm washers are worn on either dise of the con rod, its not a good idea to continue running it, even for light work. They are there to stop the rod from leaning over and creating a binding effect, this starts to agressivly wear the crank and the con rod. NOT GOOD. u should also be checking for excessive end play on the crank itself inside the cases, this can cause thos washers to wear . I would get it checked out, crank work theses days is not as limited and expensive as was in the past.. later
Elkaholic
09-06-2015 02:44 PM
