Installing new gauges...need help!!!
Old Apr 10, 2005 | 12:21 AM
SPORTSMAN70003's Avatar
Default Installing new gauges...need help!!!
Originally posted by: polarisbear500
what about an "easyout"?? i have heard of it but don't know what it is? think this will work?? and is this the rite screw i am trying to get out?? the one 3 inches to the left of the temp sensor, sorta at a diagonal slope? thanks
Yes an easy out should work if you can't get it out any other way.
Old Apr 10, 2005 | 12:54 AM
Also if you use an easy out you will probably have to drill a hole all the way threw the oil plug and you may get metal inside your motor. Here is some easy out tools.
Old Apr 10, 2005 | 01:23 AM
polarisbear500's Avatar
thanks, sportsman70003, i am gonna let my mechanic take a look at it porbably tuesday if i can't get it out with the tapping of the hammer....this sucks this had to happen...what do i do about the engine reading 200 on the temp..someone said that is too high, but my red light never comes on, the fan works just fine, and have never had a problem with it overheating that i know of.???
Old Apr 10, 2005 | 10:11 AM
200 sounds a little hot but my fan comes on at 196 so thats just 4 degrees cooler than yours. On the 700's the hot light in the pod should come on at 221 degrees. What temp does your fan turn on? Are the gauges you installed new, the temp gauge wasn't drop or anything was it?
Old Apr 10, 2005 | 10:34 AM
  #15
HELLHOUND's Avatar
Load the drill bit up with grease most of the chips will stick to the grease
Old Apr 10, 2005 | 08:16 PM
  #16
i will check tomorrow on what temp my fan comes on by just letting it sit there and idle and watching it. thanks for all the help
ReconBayou
Oct 31, 2022 05:37 PM
2many2ride
Sep 27, 2015 04:35 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
toonces
Sep 5, 2015 01:14 PM
