Amsoil Air Filter for 05 TLD
I'm using one but it's in my 04.5 700 EFI, there is a noticable differance from the stock air filter. I switched to all of their fluids also, here's my fluid list if your interested
Air Filter
Amsoil PSFA-39
Air Filter Oil
Amsoil AFO-SC
Oil Filters
Amsoil SMF-103
FRAM PH5343
WIX 51357
Motor Oil
Amsoil SAE 0W-40 Formula 4-Stroke Synthetic Motor Oil
Mobil 1 0W-40
Front Gear Case Oil Once a year
AMSoil #5 light shock therapy
Polaris Demand-Drive Hub Fluid 8 oz
Can use ATF
Rear Gear Case Oil Once a year
Amsoil SEVERE GEAR Synthetic Extreme Pressure (EP) Lubricant (75W-90) - SVG
ATV Angle Drive
GL-5 80-90 Weight
Transmission
AmSoil 2000 chaincase fluid
Polaris ATV AGL Gearcase Lube Quart
Air Filter
Amsoil PSFA-39
Air Filter Oil
Amsoil AFO-SC
Oil Filters
Amsoil SMF-103
FRAM PH5343
WIX 51357
Motor Oil
Mobil 1 0W-40
Can use ATF
ATV Angle Drive
GL-5 80-90 Weight
Transmission
Steeldon
09-09-2015 09:38 AM
