HELP SP 600
Old May 8, 2005 | 03:34 PM
2manytoys's Avatar
Default HELP SP 600
My brother inlaws 600 has no power anywhere. It has a new battery and main switch. No headlights or anything. Does anyone know what is wrong. Any fuses? I checked the circuit breaker already. Is the speedo head bad. Will it not run with a bad speedo? HELP!!!
Old May 11, 2005 | 10:21 PM
Andre's Avatar
Default HELP SP 600
Was the main switch put-in to fix the power issue? Who installed the switch? Go over the connections in the light pod. Also make sure the carb breather tube under the seat is clear, check fuel filter and drain float bowl.
Come back with more information and I'm sure someone can help. Good luck.
Old May 12, 2005 | 05:11 PM
Mudlover600Tw's Avatar
Default HELP SP 600
try to disconnect the ignition switch<key switch in pod> this may cause power loss.
