are sportsmans steering column greasable?
Old 05-25-2005, 08:39 PM
silverbullet2005's Avatar
Default are sportsmans steering column greasable?
My 2004 700EFI has a sqeek evertime I turn the handle bars and sounds like it's coming from under the handlebar area, is there a grease fitting under the pod or something? I haven't looked for myself yet but thought I'd ask, If so I'd like to get it greased before I go up north this weekend.
Old 05-25-2005, 09:06 PM
NBsportsman's Avatar
I find it funny this topic does not come up more often. This stuff is great click on the link below. Jack up the front of the bike spray it on the joint under the pod and down by the inner tierod ends while turning the handle bars left to right. I also spray the top of the struts under the cup no more squeeky front end...
>>>fluid film<<<
Old 05-25-2005, 09:15 PM
mtpockets's Avatar
>>>fluid film<<<
link doesn't work NB.
Old 05-25-2005, 09:40 PM
WGMARQ's Avatar
The link worked fine for me but I can't find anywhere around here to buy it.
Old 05-25-2005, 11:41 PM
upnort's Avatar
The 4 steering pivots that have rubber boots over them tend to squeak. Clean off, take can aerosol lithium grease and give each a spray inside boot with the long spray nozzle. Mine was doing this also.
Old 05-26-2005, 04:18 AM
jimmypsp700's Avatar
There is a zerk fitting on the shaft below the pod.
Jim
Old 05-26-2005, 11:00 AM
encorebilly's Avatar
Jim
On the o4's???
Old 05-26-2005, 11:47 AM
No grease fitting on the 04's.....
Old 05-26-2005, 03:31 PM
that's what I have heard, I will have to spray some Tri-Flow on the upper/lower parts of the steering shaft before I load up to go up north because it is very annoying to hear that squeek sound everytime you turn the handlebars.
Old 05-26-2005, 04:52 PM
tyler711's Avatar
Would WD40 work, or should I find something more like grease? That sound is driving me crazy.
Quick Reply: are sportsmans steering column greasable?
