2 Questions About The 05 700 EFI
Old Jun 3, 2005 | 11:42 AM
SPORTSMAN70003's Avatar
Default 2 Questions About The 05 700 EFI
Originally posted by: SPORTSMAN70003
Originally posted by: JAMIEZ71
First off you never want to really go down a hill fast on a polaris in low range. The back tires will lock up and could cause you to possibly slide sideways. 2nd a polaris doesn't hold back going downhill in 4x4. The polaris doesn't kick into 4x4 until it slips 20%. Normally it is hardly noticable it works so fast.
Heres a trick to get 4 wheel ebs going down a hill. Right when you start down the hill put it in reverse and turn on the awd and hold the reverse overide button and try to back up your back tires will spin causing the awd to kick in. Select low or high and go off the hill with 4 wheel ebs.
Also when you do this its usually hard the steer
EIF
Apr 20, 2017 07:15 PM
shimanok2
Jan 29, 2016 07:37 PM
Ahtatu
Sep 28, 2015 12:14 PM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
