Does 04 Trailboss 10 tooth front sprocket exist?
Old Jun 5, 2005 | 12:50 PM
MCAVS's Avatar
Default Does 04 Trailboss 10 tooth front sprocket exist?
While looking through the owners manual for my 04 trailboss I came across a section talking about using a one tooth less front sprocket so the clutch will fully engage while operating at speeds below 5mph. Although I rarely run below that speed, lowering the effective gear ratio seems like a good idea since this lead sled can use all the help it can get. It curently has an 11 tooth front sprocket. The problem is that my local dealer (almost useless) and an online Polaris vender were unable to find a 10 tooth sprocket for a Trail Boss or anything else with chain drive for that matter. Does the 10 tooth sprocket exist? And if it does what is the part number?
Thanks!
Old Jun 5, 2005 | 01:14 PM
thewayout420's Avatar
i dont think a 10 tooth exist..if there is a 10 tooth for your machine sprocket specialists would have it,give them a call 530-533-0802..what size rear sprocket do you have,40 tooth?if you cant get a 10 you could always go with a 42 tooth rear and it will pretty much give you the same effect the 10 tooth will..
Old Jun 5, 2005 | 01:43 PM
MCAVS's Avatar
thewayout420 Thanks for the reply. Yes the rear sprocket is a 40 tooth. I would rather not go any bigger on the rear sprocket as this would make it more easily damaged from rocks ect. I will give Sprocket Specialists a call. I will probably also give Rick Ridder a call Monday and order a Stage one Kit for this thing since I think I have decided to keep it. The Trailboss rides like a luxocruiser compared other machines in it's price range which is why I bought it. But it is just to heavy.
Old Jun 5, 2005 | 02:02 PM
2manytoys's Avatar
Mcavs,
You wont be able to find a 10t sprocket. Some of the boss's had 12 and 13t but they pretty much went down as far as they can go with the front. If you really want a great performance upgrade then change the Primary spring to an EPI pink or maroon. It will have the same engagement but pulld much harder in mid to top end. I gained a 7mph on the top and 800rpm's on top. Also get yourself a K&N filter. With this spring it is truely a night and day difference. Also make sure your secondary is set at the 2-2 position. It wont be a slug anymore trust me. Mine is now faster than my father inlaws 400sp.
Old Jun 5, 2005 | 03:07 PM
MCAVS's Avatar
2manytoys thanks for the reply.
I guess I'll order the Stage 1 kit from Rick Ridder because it appears to be a 1 stop soultion with most of the mods you suggest. I have noticed many people swear buy this kit. I have yet to hear of anybody swearing at it. I,m also going to put this thing on a diet. I'm going to pitch the front rear racks and weld up a new front nerf type front bumper out of 3/4 crome molly tube or something. If it had a true kick start I would loose the starter and battery as well. Any other wieght loss suggestions would be helpful.
P.S. I'm 6' tall and only 165lbs so "I" don't need the diet, the trailboss does.
Old Jun 5, 2005 | 04:31 PM
2manytoys's Avatar
Yes the stage 1 kit would be the way to go . If you want to lose more weight then get aluminum wheels. This is alot of weight lost. If you take the racks off you will find out that they really are not that heavy but I guess every little bit counts.
Old Jun 10, 2005 | 09:44 AM
spiffinmaine's Avatar
if you have the money and you are calling rick ask him about his 414 kit for the trailboss. i just got mine put back together and what a difference. i'll probably do the exhaust when i get the money saved up.
Old Jun 10, 2005 | 01:06 PM
SCRAMIN's Avatar
HEY SORYY TO REPLY LATE BUT THE TEN TOOTH EXISTS I HAVE ONE ON MY SCRAMBLER 400 IT IS MADE BUY POLARIS IT IS THE ONLY PLACE I HAVE FOUND ONE MINE COST ME $73 I WILL GO TO THE DEALER AND GET A PART NUMBER AND GET BACK TO YOU WITH IT THANKS
Old Jun 10, 2005 | 02:08 PM
scramblerXrated's Avatar
yes they do exist. i have one on my 96 trail boss. i got it on ebay tho. but it was a SUNSTAR brand. i think i gave 15 bux for it.
they are out there,,, hard to find yes, but they are out there.
X
Old Jun 10, 2005 | 02:55 PM
SCRAMIN's Avatar
EVERY CATALOG THAT IVE SEEN CARRY SUN STAR NEVER HAS THE 10 ONLY THE 11 DO YOU KNOW IF THEY MAKE IT?
