i am pissed!!!
Old Jun 23, 2005 | 10:58 PM
2manytoys's Avatar
Default i am pissed!!!
He wont have as much fuel at WOT as he would with the stock setup.
Old Jun 23, 2005 | 11:01 PM
2manytoys's Avatar
Maybe I should have said he wont gain as much top end.
Old Jun 23, 2005 | 11:07 PM
SPORTSMAN70003's Avatar
Gotcha [img]i/expressions/face-icon-small-wink.gif[/img]. By the way do you have any pics of your trucks? I have a 87 Toyota 4x4 and a 99 Tacoma TRD.
Old Jun 23, 2005 | 11:09 PM
XpLo400's Avatar
Are you talking about the 4 bolts at the bottom of the float bowl?
actually theres only 2 bolts and vise grip dont work
Old Jun 23, 2005 | 11:13 PM
  #15
I usually use vise grips to but you might try and take and hit the screwdriver with a hammer sometimes the jar helps break the bolt loose. Also put some PB Blaster on the treads that stuff is great.
Old Jun 24, 2005 | 02:02 AM
  #16
ScramaDamaDingDong's Avatar
Something like this would help
click here
or this
click here
i'm not sure what kind of tool stores you have up there but you should be able to go into a good store and something like this. Worst case you can drill the center of the bolt and use an easy-out.
Easy out type
bolt-out type
Old Jun 24, 2005 | 11:00 AM
  #17
Speedwerx's Avatar
I pm'd xplo400 we are going to get to the bottom of this and see if he purchased this from us or a dist. & to find out if he just couldn't find his jets or they are not in the hardware kit.
Old Jun 24, 2005 | 11:56 AM
  #18
ktmguy70's Avatar
I did a write up on carb Jetting on Polaris on a few other forums, and in that write up the first thing I Said to do was throw away the stock brass screws on the carb, they are worthless junk and stip easily. get some 4 mm screws from Home depot for about 15 cents and save yourself a headache in the future.
Old Jun 24, 2005 | 02:33 PM
  #19
RickRitter's Avatar
Brass screws ?
Old Jun 24, 2005 | 02:36 PM
  #20
ktmguy70's Avatar
Should clarify myself, the BRASS COLORED screws holding on your plate on top, and the screws holding on the bowl.. They Strip very easily and in all honesty, Aluminum foil would be a step up.
