i am pissed!!!
Old Jun 24, 2005 | 04:21 PM
  #21
XpLo400's Avatar
Default i am pissed!!!
yeah i have to agree,those bolts are junk...I rode it this morning with the stock 40 pilot jet and it seems to run good.The pipe is on the lound side but it makes good power.How do you know if the jetting is correct?
Old Jun 24, 2005 | 05:37 PM
  #22
SPORTSMAN70003's Avatar
Do a plug check and make sure its a light brown color.
Old Jun 24, 2005 | 06:52 PM
  #23
Speedwerx's Avatar
XpLo400 did you get my pm? Does your quad pop or back fire once you let off from a long hard pull? If so you need the richer pilot jet.
Old Jun 24, 2005 | 07:19 PM
  #24
atvaddict01's Avatar
Some people use a dremmel and cut a slot for a straight screw driver.
Before you turn give the screw driver a light tap to break it free.
Old Jun 24, 2005 | 10:27 PM
  #25
XpLo400's Avatar
I finally managed to remove the bolts,i installed the 42.5 pilot...It run great on throttle but it shut on idle...The plug was light brown.What can i do to make it iddle good?
Old Jun 24, 2005 | 11:14 PM
  #26
You will need to adjust the pilot screw in or out to make it idle right. Turn it in leans it and out makes it richer.
Old Jun 25, 2005 | 01:40 AM
  #27
XpLo400's Avatar
I guess i have to take it all apart again?If i remember right there is a round plug with a small hole under the carb,the pilot screw is under?How do i remove this plug?
Old Jun 25, 2005 | 08:08 AM
  #28
When I took mine out I drilled a small hole it the brass plug took a big screw and screwed it in the hole and took some vise grips and put on the screw and pulled the plug right out.
awer1968
Sep 8, 2015 11:02 AM
Coryco
Jul 6, 2015 07:30 PM
Arcosanti
Dec 15, 2000 01:58 AM
Bill.Ciliberti
Oct 1, 2000 12:58 PM
givasum
Sep 26, 2000 12:46 AM
