sportsman 500 ho jetting???
Old 06-30-2005 | 06:43 PM
braveops's Avatar
Default sportsman 500 ho jetting???
have been running a 147.5 for a long time and has been pretty good compared to the stock 152 are any of you running a 145main?if so what mods and did you find it alot better than the others?
Old 07-01-2005 | 11:06 AM
NBsportsman's Avatar
I have the stock 152.5 in mine and find in the warm weather it runs too rich. Have dropped the needle two notches and is better but want to jet down to 150 or after reading your post maybe 147.5. I see you live in BC what altitude do you normally run at??
Old 07-01-2005 | 05:34 PM
braveops's Avatar
i would go with the 147 it will wake up the 500 by quite abit just put the needle back to stock and in the winter u might have to go up 1 size. i dont have to on mine at home i am about 1700ft and i ride any where from that to around 5500-6000ft and no problems i just want to see if i can sqeeze abit more out of it.winter time i have to pull the choke on till it runs abit maybe 20 seconds being it is in my garage it hesatates when u first fire up cold then it is fine
Old 07-01-2005 | 08:58 PM
All my running is below 2000ft but I think I will try the 147. You can tell the difference on the hot humidt days it almost starts to bog under full throttle and fells slugish. Before I dropped the needle it would start in winter with out the choke. A bit off topic but what size are your Bearclaws and how do you like them??
Old 07-02-2005 | 01:45 PM
braveops's Avatar
i think they are great the fronts are stock size and backs are 25x12.50x10 1300 miles on the back ones and still work great
Cole Hadden
08-25-2020 12:11 AM
house1
08-09-2015 11:49 PM
GregM
07-29-2015 10:41 PM
bpegram84
07-22-2015 09:15 AM
bpegram84
07-22-2015 09:12 AM
