New tires for sportsman400
#15
I believe it was $158.00 fron Cob over at atvquadsquad.com
I noticed a difference on the low end, which is where I needed improvements on the hookup. I like slow techincal stuff and it works great in that range. I get engagement just off of idle, somewhere around 1300 rpm.
#18
There isn't much adjustment to make on the H/C with the 400 like there is on the bigger bores. But overall I believe it is a better setup than the stock parts. 100%?...I'd say maybe more like 85% of monies worth.
I also changed the ratio of the driven clutch to get the engine braking. Not a lot in high gear, but brakes like heck in low
#19
Thanks kushman.
Bob, I meant the HC, but actually thanks for the positive words, I think I am pretty sold and that helped. I'll take a look around and see what I can find. Plus I'll have spares, If I rip a sidewall (like I have to several 489's in the past) I could have a shop switch it until I get set up again, another plus to not upsizing.
