HeLp! Sportsman dies when in water ??????
Not sure about the plugs....but I have read about carb. vent tubes causeing this many times on the fourms. don't know if your quad has a vent tube hanging down under it or not my friends did and it would die every time he got the tube under water. It also seemed electrical but was just the tube first he shortened the tube. And then routed it into the airbox later on to make sure it stayed dry.
The two plugs on the transmission are the gear position switches. They send a message to the pod as to what gear you are in. When they go bad it won't show H<L<R on the pod. Not your problem.... I think it is running too rich and a quick easy way to see is raise the "C" clip on the needle valve which is under the gold dome on top of the carb. Pull the dome and the diaphram the needle is inside. Lift the "C" clip up two notches and try that. My HO was bogging under load last summer and that was the fix. THis summer I jetted down two main jet sizes and it flat out rocks now....
#18
thats wat happened to my buddy's 400 kodiak wen we went riding today. he went through a lil water and his quad just completeley shut down and he couldnt get it started. we drained everything and tried all we could but it still wouldnt start. i thing its his carb but im not sure. it was fun for me though kuz i get to tow him. yum..... i love towing other peoples quads kuz it makes me feel good hahahaha [img]i/expressions/face-icon-small-smile.gif[/img] good luck with that though.
