help quick, installing new primary spring!!!!
Old Aug 1, 2005 | 07:54 PM
garrett5462's Avatar
Default help quick, installing new primary spring!!!!
i took off the black plasticf guard and see were the old blue spring is, but how do i put my new one in? the manual doesnt seem to help. do i take off the gold bolt in the middle of the clutch? is so, how? i dont have that big white thing that the guy has in the picture. how do you guys do this?!!
Old Aug 1, 2005 | 08:09 PM
GE4x4's Avatar
The center bolt and the cover bolts come off. I use a small pipe to hold the clutch while you loosen the center bolt. It only takes about 10 min. to do.
Old Aug 1, 2005 | 08:10 PM
SPORTSMAN70003's Avatar
Take the 6 small bolts out then take the 1 big one in the center out of the primary and pull the cover off. You should be able to slide the old spring right out. Just reverse the directions to install.
Old Aug 1, 2005 | 08:42 PM
fishslab's Avatar
Those six little bolts on the corners take apx 90 in/lbs for torque (7.5 ft/lbs) don't over tighten them. The main bolt takes 40 ft/lbs of torque.
Rooky
Sep 9, 2015 03:16 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
WilliamBos
Sep 6, 2015 10:53 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
toonces
Sep 5, 2015 01:14 PM
