Another scrammy issue
Old Aug 3, 2005 | 06:39 PM
Bretman's Avatar
Default Another scrammy issue
i dont get why it would be in there, besides i just put a new belt on in there and cover and inspected my clutches. Scramblerxrated my chain looks to be in good shape as far as the rollers and the sprockets are all good. My front sprocket comming out of the tranny seems to be losse. Is that normal thought. I can move it back and forth kind of. My chain is also verry dry, there is no lubrication on this thing at all, think that coud be it.
Old Aug 3, 2005 | 06:58 PM
rieds's Avatar
what i meant was if it's in your tranny case you can feel it when you lay your leg against the clutch cover because your secondary clutch mounts on the input shaft of the tranny. if it was the chain in your tranny getting loose every time you hear that ticking noise you can feel it. maybe you just need to lube your drive chain.
Old Aug 3, 2005 | 07:00 PM
Bretman's Avatar
maybe, thanks for the info
Old Aug 4, 2005 | 03:43 AM
jimmypsp700's Avatar
Originally posted by: Bretman
what will that do though, when you sit on it the chain tightens up anyways because you make the swing are flex up and down.
Not really if you have a concentric drive quad.
Tighten it if its loose.
Jim
COFatboy
May 2, 2020 12:06 AM
Jenn1
Sep 8, 2015 09:16 AM
cody500ho
14
Aug 14, 2015 05:03 PM
WesTech
11
Aug 11, 2015 07:55 AM
Unzzy66
Jul 11, 2015 10:01 PM
