Sportsman 600 fluids
Is there something you can use in place of the Polaris AGL. It would be nice to have something I can get more easily. Also does anyone know the size of the drain plugs for the engine and the transmission?
Thanks for the help.
the oil drain plug is a 6mm allen. use only full synthetic 0w40.
I would not substitute the front diff fluid.
the rear gearcase uses GL5 80-90
Jim
from another post...
Rather than using the Polaris AGL, you could use any good quality Dextron III ATF - since it's the same lube except for the color. It takes 335 milliliters (11.5 oz.) from empty.
Stirling
Aug 9, 2015 01:49 PM
rjacree
1) Engine problems..
Aug 3, 2015 10:21 AM
2004, 600, agl, alternative, change, fluid, fluids, forum, lube, lubricants, oil, polaris, sportman, sportsman, substitute, transmission
