Trailblazer problems
Old Oct 21, 2000 | 03:43 PM
Cobra131's Avatar
ok, well I was out riding about 2 weeks ago and it just shut off on me. So we towed it back home and started trying to figure out what was wrong, couldnt figure it out, sprayed some starter fluid in it and after some hesitaion it fired back up, well I was out riding again and it did the same thing. It gradually lost power till it stopped, I checked the spark plug, it was fine, even put a new one in it. It is getting fuel, we checked that, but it didnt seem like the spark was real strong on the plug. Any one have any ideas what could be wrong? thnx
Cobra - 2000 Trailblazer
HPD Pipe, HPD Clutch Kit, K&N Airfilter
Old Oct 23, 2000 | 12:15 PM
RobCulp's Avatar
Did you look for Aluminum on the plug and do a compression test?
Old Oct 23, 2000 | 08:20 PM
Cobra131's Avatar
I did the compression check and it was fine, and I tried 2 brand new spark plugs in it still wouldnt start, it is getting fuel we know that, but it just wont turn over, I was thinking it might be an electrical problem or something?
Cobra
Old Oct 23, 2000 | 09:55 PM
scramdaddy400's Avatar
It could be many things I'm gonna give ya a list of things to try out. Some things you'll need a voltage meter. When you use the volt meter make shore the key is turned on and always ground to the frame.
1. check the red engine shut off switch you could of bumped it off on accident.
2. check your voltage through the spark plug cap.
3. check all your wire connections.
4. check the carb over for any jet problems only because it's getting gas does'nt mean it's going to run the carb is the heart of the machine.
5. check the reed valve you could of broke a reed that's not unusual.
6. if all else fails pop the head off and see if the piston burnt up if that happened theres a problem with your jetting.
If you find out the problem e-mail me back I'd like to hear what went wrong.
GOOD LUCK
2000 SCRAMBLER 400 2X4
SCRAMDADDY400
Old Oct 25, 2000 | 10:33 PM
waynaferd's Avatar
(the 250 don't have reeds).......
Old Oct 26, 2000 | 08:40 PM
Cobra131's Avatar
Yep, traiblazer dont have any reeds (Polaris, if ur reading this, PLZ make the new ones w/ reeds!). Well I am taking it to my dealer on Saturday and I will inform you then what he finds wrong, cant wait to see what it is.
Cobra
2000 Trailblazer - HPD Pipe, HPD Clutch Kit, K&N Airfilter
Old Oct 27, 2000 | 06:02 PM
RobCulp's Avatar
Cobra, what main jet are you running with your mods?
Old Oct 27, 2000 | 10:27 PM
Cobra131's Avatar
a 140 I think, its the one that came with the pipe.
Cobra
Old Oct 29, 2000 | 09:38 PM
Cobra131's Avatar
well, the verdict is in, seems like there is a hole in the piston! we had it jetted wrong and thats how it happened! oh well, lol
Cobra
Old Oct 29, 2000 | 10:13 PM
o2b4unc's Avatar
Thanks for commenting back...I have one and was watching for the outcome. Most folks wouldn't have acknowledged being part of the problem...
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
shewshew989
Jul 14, 2015 03:09 AM
shewshew989
Jul 14, 2015 02:54 AM
