sp400 cv shaft replacement
Old Oct 4, 2005 | 01:56 AM
hobson221's Avatar
Default sp400 cv shaft replacement
I have an 01 sp400 with a broken cv shaft. I'm to the point where it won't pull out from where it slides in to the transmission. I'm out of ideas and need some help. Also I was wondering if the local cv shaft shop would be able to fix it or am I going to have to dish out the $300 and buy me a new one?? Any info is much appreciated! Thanks!!
Old Oct 7, 2005 | 01:05 AM
THECVMAN's Avatar
Hi,
On the 04 Sportsman 400 the inner yoke is held in with a "c" clip. Just pry the yoke away from the differential and it should compress and slide right out. Sometimes you need to rotate the axle and tap on the yoke lighly to get the clip to center itself. PM me if you need and pointers I know all about these things.
Thanks,
Danny
"thecvman"
P.S. See the picture at: http://parts.polarisind.com/Assemblies.asp
Old Oct 7, 2005 | 12:28 PM
hobson221's Avatar
Hey Danny,
I've got the cv shaft out now and am kind of confused. The reason I thought it was broke was because of the loud clicking noise it was making from the rear and then upon checking it out the inner cv boot was tore open so I just assumed it was the cv shaft. The cv shaft itslelf looks good with no obvious damage. Should I take it somewhere and have them check it out or should I just buy a new boot kit and slap it back in there? Could it be something else??? Thanks for the pointers you gave me before and any info you give now is much appreciated. Thanks
Jeremy Hobson
Old Oct 7, 2005 | 01:49 PM
THECVMAN's Avatar
Hi Jeremy,
If your getting a clicking sound then your inner cv joint probably has a bad cage. I would recommend giving it a go yourself since it's not that hard of a job and you'll save a bunch of money and learn something at the same time. PM me and I can walk you through the process.
Thanks,
Danny
Cole Hadden
Jun 15, 2025 09:05 AM
toonces
Jul 28, 2015 01:58 PM
carolinabomb
Jul 26, 2015 08:40 AM
joeyupton
Jul 14, 2015 11:51 AM
tporath
Jul 11, 2015 12:31 PM
