scrambler 400 pipe
Old Oct 12, 2005 | 12:38 AM
  #21
oghma's Avatar
Default scrambler 400 pipe
I have had the FMF gnarly with the turbinecoreII silencer and I actually liked it. BUT it does not make the performance gains that the other pipes will. I now have the CPI pipe and love it wouldnt change it unless I went with RCR topend pipe. BTW I do not have porting done.
Old Oct 12, 2005 | 07:46 AM
  #22
ftwflh's Avatar
Originally posted by: RealAce
and i have another question if i got a whitebros air filter with say a dynoport full exaust would i have to get new clutch springs or would just rejetting it b enough
You would have to rejet with any pipe.And with the Dynoport the clutching would be up to you and you could do that later and it would still run better.
Old Oct 12, 2005 | 11:07 AM
  #23
conig's Avatar
with a scrambler 400 you willhave to get away from the "name brands" they either don;t make parts for them or half assed there R&D to make something that would give a gain but not much.
dynoport and CPI make pipes for banshees and are well known in that croud. AAEN and HPD are devoted to polaris only and have years of snow mobile tuning behind them. The scrambler 400 2x4 is essentially that a snowmobile with 4 wheels. The dyno port would be good, I would also do alittle more work to the air box. (cut out the wall modify the snorkel)
Do a search for dynoport with user name bubba297 theres good info. I like the AAEN and my cltuch setup is cheaply done if your looking to save some bread. 2 springs is all you need to make any of these pipes run well.
Old Oct 12, 2005 | 11:51 PM
  #24
RealAce's Avatar
ok thank you guys for all the help i am looking into getting a polaris 400 aaen top end pipe with a top end spark arrestor silencor with a clutch kit and a whit bros air filter and possibly a white bros filtered air box vent i owe u guys alot thanx for the help
Old Oct 13, 2005 | 07:39 PM
  #25
scramblered's Avatar
guys,the question was about minor change choice for a pipe,
i known what pipe are best for the 400 as for race mod kit on high
octane gas,and it is HPD atvrp8,CPI race mod pipe,FTR race pipe or the old lrd pipe for the 400 polaris was not that bad,,pick what you need
and the truth is out there...
Old Oct 14, 2005 | 11:07 AM
  #26
conig's Avatar
RealAce you wont be sorry with the AAEN top its loud but a great power maker.
Old Oct 14, 2005 | 02:51 PM
  #27
KeninAZ's Avatar
hey guys, I just bought my quad and it has the FMF gnarly pipe on it, haven't riden it yet, but
from what I have read it (fmf pipe) has big gains down low, but on top it is about close to stock
are these other pipes big on the bottom and top end?
I'm a big guy, 6' 1" and 240lbs, so a bit of bottom end grunt would be good for me, but if I'm missing out on top also....I'd get a new pipe
thanks
Ken
Old Oct 14, 2005 | 04:41 PM
  #28
conig's Avatar
I would wait until you ride it. The FMF is a highly depatable topic few have had the pipe some like it some don't. the real problem is the full power of that pipe will never be realized as no one knows for sure how to set the clutch up to match its RPMS.
Old Oct 17, 2005 | 11:48 PM
  #29
RealAce's Avatar
ok im a beginner with this stuff on the aaen performance website for a 400 scrambler it has: Boyesen Double Reeds
Mounts on your stock cage. Boosts power and throttle response thru the powerband.
that means that i dont have to buy any thing seperate with this just the double reeds and that would b all nothing to attach it to right
Old Oct 18, 2005 | 05:10 PM
  #30
scrambansheeman's Avatar
ive had hotseat,psi,fmf, 2 hpd pipes. go with the hpd full race pipe. no leg heat fits like a glove and runs awesome. i ran it on the trail mod and it was great. now have the pipe on a full race mod and it works great for that also
