HELP?/PRED CARB PROB?
Old Oct 14, 2005 | 07:32 PM
atvstan's Avatar
Default HELP?/PRED CARB PROB?
Well i cut 4 coils off spring and drilled 1/8th holes in slide, really dont know much about stock carb, and someone said put the needle on first notch or something, what notch? and i'am using a 162.5MJ and 42.5 pilot with 1 1/2 turn out on mixture screw, but it still is running rich and when i take carb off gas is inside manifold. getting frustrated race is tom. so any help would be great?
Old Oct 14, 2005 | 08:32 PM
atvstan's Avatar
anyone?
Old Oct 14, 2005 | 09:29 PM
predle05's Avatar
top of needle has 4 notches with a small clip , take out the clip move it to the top notch for leaner
Old Oct 14, 2005 | 09:30 PM
predle05's Avatar
if thats not enough change main jet to 160
Old Oct 14, 2005 | 09:35 PM
predle05's Avatar
always make small changes if your close.. and only one change at atime
Old Oct 14, 2005 | 11:30 PM
atvstan's Avatar
well i change my MJ to 160 and put needle on first notch from top and 1 3/4 on mix screw, accerlates good but when i floor it quick it bogs, but it was doing same thing before i changed anything
Old Oct 15, 2005 | 12:53 AM
predle05's Avatar
mines a mikuni carb but iknow most people running your mods are around a 170 main
Old Oct 15, 2005 | 12:55 AM
predle05's Avatar
whats your elevation
Old Oct 15, 2005 | 01:23 AM
atvstan's Avatar
i'm at 1200ft its mikuni, spark plug is a tad bit black, when i hit about 2nd gear it starts to bog
Old Oct 15, 2005 | 01:25 AM
predle05's Avatar
keep going down on the main if you think its getting better like a155 ..if it gets worse hit a 170 let me know how it turns out iknow you get alot of info from predatorowners.com
