Removing old gasket material
Old Oct 15, 2005 | 06:23 PM
gearheadjdr's Avatar
Default Removing old gasket material
What is the best way to remove the old gasket material from an engine case?
Old Oct 15, 2005 | 07:08 PM
powerslider's Avatar
Tap lightly with a hammer around the gasket surface then use a good gasket scraper.....
Old Oct 16, 2005 | 12:33 AM
cr125predator's Avatar
psh, i just use a razer blade.[img]i/expressions/face-icon-small-happy.gif[/img]
Old Oct 16, 2005 | 03:35 AM
Doctorturbo's Avatar
GOT BOOST!
Hit it lightly with a cookie cutter on an air grinder. Don't get into it to hard or you will start pulling aluminum.
Old Oct 16, 2005 | 09:19 AM
ftwflh's Avatar
Permatex makes a gasket removing spray that works good.I use it in hard to reach situations.It take a few minutes but you dont gouge the alluminum with it.
NRA+1
1) Engine problems..
10
Sep 20, 2015 08:47 PM
Elkaholic
Sep 6, 2015 02:44 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
toonces
Sep 5, 2015 01:14 PM
Jason Richards
Sep 4, 2015 06:17 PM
