96 TrailBlazer ?s
Any1 have any idea what size tank sits on a 96 Polaris TrailBlazer? Having hard time finding answer.
Any1 have a hard time starting one? If did and fixed it, What did U do? I have played w/ it and still it has problems starting w/ or w/o Choke. It can b 90 some degrees out and
Its a real pain to start.
Please respond or e me at cute2482@yahoo. Thanks.
I take it u are not the original owner, there are lots of little things u can check for hard starting, but
why not check the compression & see if it is good, should be around 110 psi. it is a quick test. I did
a bunch of other checks on mine, many of them twice, when mine was starting hard, then someone on the forums said test the compression, I did and it was 90 psi. I did a top end job that put it at 115 psi.
& it was starting great after that. the gas tank on my 02tb is 3.5 gallons not sure if the 96 is the same.
Thanks for the tip. Im not the original owner. They abandoned it at a Motorsports shop here in Phoenix to b worked on and never returned message bout cost to fix. It sat there for a longggg time. So friend gave it to me. Only had 6 hrs on it when whoever it was, Toasted part of the motor.. So I sunk in the cash and did fixed it myself. Im working on sooping it up. Id love to know what the original owner did to it~ idiot. Anyways, Again thanks for the tip. If any1 else thinks of anything, e me.
