terrible day, snapped a drive shaft...look
terrible day, snapped a prop shaft...look
Originally posted by: BryceGTX
Hey elkbow.. I thought the same thing as baxy. Looks like the CV over extended and came apart. Do you have any front suspension mods?
Bryce
Bryce
I was looking at it, I think you are right, it overextended and pulled itself out....I was looking at the end, the shaft looks okay, but the cv joint and boot are totalled, parts/pieces and all but two of the bearings are gone.....i think the end of the shaft is okay, never worked on a cv before, so not sure how it all goes together...but i'll figure it out
dave
Originally posted by: elkbow
Bryce,
Just looked up the parts on Polarisoemparts.com, wow, the outer CV joint assembly is $174.99 ($199 retail) and the boot kit is $26.49.....I can buy the whole thing for $250....maybe thecvman.com is the way to go....
dave
Bryce,
dave
Bryce
#15
Ouch.. Maybe "thecvman" could tell us why this CV came apart. If the suspension can drop more than stock, the CV will come apart. But you'd think a stock suspension could not have this problem.
Bryce
Bryce,
dave
Bryce,
dave
Bryce
do you know how the shaft is attached to the front drive housing? the manual shows it as a pin....but it shows a picture of an '04 type model with a u-joint, yet the page before shows the cv jointed shaft....terrible manual....
#16
Bryce
#17
I looked at a Polaris parts manual and it appears there is a c-clip slot on the inner CV spline. But when I look at the front diff break apart, I don't see how the c-clip can hold it in unless the inner CVT just pops in and out of the front diff with a bit of force kinda like a socket on a rachet.
Bryce
Bryce
#18
#19
on a regular automotive style cv joint most of the time you cut off the torn boot then tap the joint off the shaft over a spring loaded clip
sometimes you need to release a snap ring in a cut out part of the joint where it slides over the shaft
wash off the old grease and have a look for a clip
#20
thats what i was seeing...i'll figure it out, even if i have to ask the dealer...ok, maybe not...lol
Bryce
Bryce
