PRED 500 JETTING
I have an 05 500 and just ordered a Yosh full system and K&N snorkel air filter system to replace the lid and stock flat filter set up. Stock jet is a 150. Any recommendations on what I should jet up to. Use is just about always at sea level. I was told 165 to 170? Also, I have heard that I have to adjust the needle to the 4th position and then also adjust the fuel / air screw?
Thanks in advance.
- Walt
Thanks in advance.
- Walt
Originally posted by: hudson4269
At 150 jet I am running SUPER lean at 1000 ft elevation and around 80 degrees.
Im going to a 160 and everything is stock so I would say start at 165 to 170 and go up.
BYC
Sep 25, 2015 02:10 PM
