OIL CHANGE
#21
OIL CHANGE
Maybe someone can answer a question for me since where on the subject of oil. 2 years ago when I bought my TB250. I bought a white gallon jug with a flex nozzle spout of Polaris premium 2 cycle lubricant. No where on the container does it say that it is synthetic. It is blue in color. Then last year I bought a quart of blue 2 cycle Polaris oil and it clearly says that it is synthetic. I was wanting to know if the first gallon of blue 2 cycle polaris oil that I bought was synthetic, even though it doesnt say so on the container. And do you know if when it was new from factory if it was given synthetic oil. Just one of those things that make you go hum.
#24
#25
OIL CHANGE
I would not worry about having 0-40 unless you ride in sub zero temps. I do know it gets cold in North Dakota and if you ride in such temps then 0-40 may be what you need. Mobile One synthetic is good oil and it will work fine in your ATV.
In Ky where I live normal temps run from the teens to about 95. 5w50 is perfect for Ky weather.
#26
#27
#28
#29
