800 EFI Belt of EBS Noise???
Old Dec 3, 2005 | 09:21 PM
WISPORTSMAN800EFI's Avatar
Default 800 EFI Belt of EBS Noise???
My 2005 800 EFI Sportsman (30 hours) has started making a noise that appears to be coming from the belt or the EBS when you hit the throttle and when the engine is reving down. This happens both when in H, L or Park. It sounds like a belt squell, but I am not sure why it happens in Park? I also saw in another post that the 2005 800 EFI had some belt problems. What were the belt problems with the 800's and how would I know if that is what is happening to mine? I had mine into my dealer before my warranty ran out and they said the belt was fine. Any thoughts?
The dealer said that some ATV's make this noise and some do not and that it is it is due to the clutch engaging the running belt which is causing the squell. The ATV runs great and I have been plowing snow without any problems, its just that the noise sounds like crap. Thanks for your help.
Old Dec 3, 2005 | 10:04 PM
spyder6's Avatar
if it sounds like you have rocks in your transmition, its normal, all sportsmans do it, its the slack of the belt on the EBS system
Old Dec 3, 2005 | 11:53 PM
SACtrainedkiller's Avatar
spyder6
Is there a way to shim this slack in the clutch to minimize this (*****-in-a-paint-can) noise?
Both my 2006 machines do this and have done this since mile 1. No big deal, I am used to Polaris noises, but was wondering about a fix you may be aware of or something? Thanks
Old Dec 3, 2005 | 11:59 PM
spyder6's Avatar
all the Twin models do it, and there isnt a way to get rid of it, that is unless you get rid of the EBS entirely.
Jeff Roper
Feb 1, 2022 11:48 AM
mrtidy
Feb 3, 2016 05:00 PM
Ahtatu
Sep 28, 2015 12:14 PM
kbazzy
Sep 26, 2015 11:26 AM
