Overheating Sportsman
Old Dec 11, 2005 | 02:08 PM
Rawzon's Avatar
Default Overheating Sportsman
that switch is controlled by the temperature, its a thermo temperature switch.. if its stuck on hot... it'll tell you its hot all the time
Old Dec 11, 2005 | 02:23 PM
sigarms229's Avatar
Thanks for all the info, I'll look into replacing the switch first.
Also, it looks like this switch is the same thing as the sensor 2manytoys was talking about. Polaris part number 3089246
Old Dec 11, 2005 | 05:35 PM
hydro's Avatar
There is a service bulletin on some of these machine about a bad ECU causing that condition you need to see if you falls it to that first. If it does the repair is free for a 200.00 part and the labor.
If you contact me I can check and see if yours needs the update
Old Dec 11, 2005 | 08:15 PM
alfredo's Avatar
call polaris. they will tell you how to reset the computer
Old Dec 11, 2005 | 11:59 PM
  #15
sigarms229's Avatar
Hydro, PM sent.
Old Dec 12, 2005 | 03:40 PM
  #16
hydro's Avatar
Reply has been sent.
Old Dec 12, 2005 | 05:32 PM
  #17
sigarms229's Avatar
Hydro, nothing in my PM inbox, try again or email me at jstapf@yahoo.com
Thanks.
John
Old Dec 12, 2005 | 08:59 PM
  #18
hydro's Avatar
I sent one again but in case you don't get it. I check the bulletin and yours does not fall within the serial number range, but the problem you having is very common with a failed ECU. You may want to take it to the dealer they have a module that can test it. Also the ECU is NOT resetable it either good or bad. Hope this helps---Hydro[img]i/expressions/face-icon-small-smile.gif[/img]
Old Dec 28, 2005 | 11:35 PM
  #19
JHEdmonton's Avatar
I own a 500 sportsman and also have an overheating problem. Manufactured: 08/05/2003
The temperature sensor has 5 kb and even with it unplugged, no hot light nor fan turning.
The fan itself is OK (provided 12V at the fan connector as a test)
There was a relay mentioned? Where is that located? How can I test? Does anybody have a electric diagram of the fan and the temp sensor?
Other suggestions?
Thanks,
JHEdmonton
Old Dec 29, 2005 | 02:16 AM
  #20
Rawzon's Avatar
on mine its right below the ecu, its a black box maybe 5x5in.. although i read that on the newer models there is a capacitor that will go first so that you dont burn out the relay like i had.
Jenn1
Sep 8, 2015 09:16 AM
MikeyBoyesq
Aug 10, 2015 11:11 AM
cornermike
Jul 30, 2015 06:37 AM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
