250 backfires on acceleration
Old Dec 19, 2005 | 09:35 PM
400EXerciser's Avatar
Default 250 backfires on acceleration
Need a little help. I just rebuilt the engine in my wifes 88 Trail Boss ES. It has a rebuilt top end and bottom. The carb was also rebuilt. For the breakin I am running a 38:1 gas to oil as I have removed the oil pump. The atv starts and idles great. The problem is when I rap the throttle it backfires through the carb. Is this a lean condition? Do I need to raise the needle ? I have the pilot screw turned out 1 1/4 turns. If I open the throttle slowly it will build up rpms. Is it not true if you open the carb real fast and it backfires it is because you get a sudden rush of air and the fuel can't keep up? Thanks for any help
Old Dec 19, 2005 | 10:06 PM
IdahoVinnie's Avatar
You definitely are on the right track. A lean condition generally causes a backfire through the carb. Raising the needle (lowering the clip) causes the needle to be raised higher out of the jet that it sits in, therefore enrichening the mixture.
I wish that I could be more specific on the proper adjustments to make, but I'm not that familiar with your atv. I'm sure that others will be able to be of better help.
ReconBayou
Oct 31, 2022 05:37 PM
fordfaithful21
Dec 7, 2015 05:52 PM
handyjc1
ATC 3-Wheelers
Oct 23, 2015 07:15 PM
alzgarvin
Sep 11, 2015 08:53 AM
Brandon400
Sep 7, 2015 12:20 PM
