L&R Rear Cargo Box ?
Got a Lock & Ride Rear Cargo Box for Christmas. Is it supposed to come with the anchors to hold the box down? Mine didn't. They are $25 each, and I assume I need two. Anybody have one? Did it come with the anchors?
I also got the rear seatback and side bags. Will be nice when they are all installed.
Thanks.
Thanks.
Well, my dealer did send me one anchor (instead of 2), but not the mounting hardware that attaches to the box. Can you tell me what came in the hardware package? I assume I need two mounting brackets and two anchors. I will be calling my dealer this afternoon. Thanks again for any help.
Thanks powerslider. That's what I thought by looking at the box. Called the dealer and they said they will send me a hardware pack from another box. Hope everything is there this time.
Bytor, that rear seat back is awsome for long rides and riding 2x. My cargo box came with lock and ride hardware, back rest (attached) & side bag anchors. I didn't get the side bags because they were trying to charge me $40 each for them and I knew they only run $20. The only problem I've had with the box is trying to ride hard with alot of loose weight in it makes the anchors slide out and come loose. You'll also see some grooves cut in the front and back of the inside of the box. This is a great place to insert some fabricated plexi-glass dividers.
When you fabricate the dividers you have to remember to leave about 1.5"s sticking out the top to conform to the inside of the lid. I had to learn the hard way. Mine are not that pretty but they sit in the box tight. I've also filled a section with a block of foam with slits in it to hold drinks, car keys, smokes, and what ever else needs to stay secured and dry. Good Luck!
