05 700 efi oil filter
Old Feb 24, 2006 | 12:08 AM
JCDEYO25's Avatar
Default 05 700 efi oil filter
I've heard good things about the Puralator oil filter......I use that and Mobil 1 0W-40 synthetic.....The only Polaris fluid I use is the Demand Drive Fluid for the front gearcase just because sometimes the engagement of the FWD is a little particular.......
John
Old Feb 24, 2006 | 05:27 AM
jimmypsp700's Avatar
I use 0w40 Mobil 1 only ($5.49). Especially in the winter.
No need for special 4 stroke (wet clutch ) high priced oil here.
-600/700 twins oil filter-Polaris #2540006
http://www.wixfilters.com/filterlookup/atv.asp
WIX p/n 51357
NAPA 1357
STP S6607
Amsoil P502057
-500 HO 4 stroke oil filter-Polaris #
Wix 51356
Purulator 14610
AC Delco PF 2057
Pure One L 14610
Champion ST 7317
Fram PH 7317 or TG7317
Napa 1356
P 14610 crosses to a AC Delco PF 2057, much better filter for $3.69.
the AC has a anti drain back and relief valve.
you have to watch for, is does it have a backflow on it?
In other words, when you shut off the bike with a Polaris filter (and some other filter's) the oil stays in the filter.
But with the Fram filter the oil drains out of the filter when you shut it off.
I don't know what the Purulator does??
NOW they finally changed the Powersports and Motorcycle Application Guide, and list a NEW filter number for the twins. P502057
Old Feb 24, 2006 | 07:29 AM
tstroker's Avatar
the p14610 twin, p14612 single, all have the relief and anti drainback valves, also are at or near the top on oil filter comparison tests....
Old Feb 24, 2006 | 09:16 AM
ATVRIDER500's Avatar
I know I didnt start the question ,but I sure learned alot
Old Feb 24, 2006 | 12:30 PM
  #15
WGMARQ's Avatar
Where do you get the Purolator filters ?
Old Feb 24, 2006 | 02:30 PM
  #16
zerowick's Avatar
Oil Filter Test
Old Feb 24, 2006 | 03:40 PM
  #17
WGMARQ's Avatar
Anyone have the WIX OR Mobile 1 oil filter part numbers ?
Old Feb 24, 2006 | 03:52 PM
  #18
zerowick's Avatar
Wix # 51357
Old Feb 24, 2006 | 04:03 PM
  #19
WGMARQ's Avatar
This should help WIX ATV oil filter guide
Old Feb 24, 2006 | 04:23 PM
  #20
JCDEYO25's Avatar
WGMARQ............
Advance Auto Parts has the puralators.
John
