2003 600 twin ???????????????
Old Jan 6, 2006 | 10:06 PM
  #21
GoingVirtical's Avatar
Default 2003 600 twin ???????????????
Originally posted by: DANO38
I should have kept my '03sp600!!! Great machine!!! I think it was actually a little snappier off idle than my sp700efi is, but it couldn't even compare to the top end of the efi's! The gas mileage is a little better on my sp700efi also, but my sp600 cost me about $600.00 less also! Only thing I disliked was how it ran before I installed the carb update kit. After that it ran perfectly!
I should have kept my 03 600 too. I sold it for a new 700 efi and should have saved my money. Had it for 3 years loved every minute if it. It climbed muddy hills that my new 700 won't do (Goodyear rawhides where awsome)
Old Jan 6, 2006 | 11:08 PM
  #22
zerowick's Avatar
[qThe one @ sportsman's warehouse, weighs under 200 lbs, with a 1000 lb capacity ($750 in the store)
.[/quote]
I like the sounds of this one, you might regret the heavy one. my smaller one weighs around 300+ with over 50 pounds of tongue weight for balance when loaded and it is a pain in the a$$. it is great for stone, sand, and gravel because the tires have a larger diameter and width which allows for good floatation, but hitching and unhitching are a feat.
peace
Old Jan 6, 2006 | 11:20 PM
  #23
ncriderforks's Avatar
The twin motors are all great. (600, 700, 800). what alot of people don't know is that the 600 will out pull the 700 on a wieght tranfer sled. shorter stroke lets it rev up quicker which gives a faster wheel speed.
Old Jan 6, 2006 | 11:25 PM
  #24
zerowick's Avatar
new guy huh? welcome aboard! the 600 is quite a puller for sure!
Old Jan 7, 2006 | 12:32 AM
  #25
thanks for the welcome. Polaris is my job. And i love to talk about them, good times or problems. I do alot with Polaris when they do testing and evaluation.(as contract help when needed). Those guys really have alot of heart, real blue collar guys. If the white collars would just listen instead of thinking they know it all then polaris would be unstoppable. Lots of friends there that know alot. So if i can help, let me know
Old Jan 10, 2006 | 03:32 AM
  #26
jimmypsp700's Avatar
I have had good luck with bioth my polaris' and i love my 02 sp700!
One thing to check is the carb boot /adaptor for cracks and the hall speedo sensor may go bad ($42). also some early models had water pump leaks that was fixed under warrty w/ a steel cover.
Jim
Old Mar 8, 2006 | 01:24 PM
  #27
Lonelyduke's Avatar
I'm glad all you guys have had good luck with your 600's, because mine has been a piece of junk. It broke down twice while riding in Utah, first time was a bolt holding in the steel bushing on the rear hub to A-arm sheared off. The second time was when the stator went bad. Luckily that only cost me the last day of riding. Then, just the other week, while riding in WV, my crankshaft bearings went out. Luckily on the way back to the trailhead on the last day. That's 2 major expences of about $1000 each. Luckily, I had purchased an extended warranty.
So, as soon as I can get it fixed, I'm getting rid of it and going to another brand.
Old Mar 10, 2006 | 07:07 PM
  #28
300ex90's Avatar
I had a '03 and it was a great machine, awesome power, reliabilty even after it was rolled down a hill (I wasnt riding it) the only thing that happend was a bent rim and a broken rear rack after that no problems at all though i did trade it in on a grand cherokee not a bad trade but REALLY MISS IT AND REGRET IT!!!.... o yea its also a great mud machine i never got stuck once with the stock goodyear rawhides
Old Mar 11, 2006 | 12:23 AM
  #29
Charlie's Avatar
The 600 twin is a great engine. The only problem I have ever had is a sticky lifter on occassion. Usually when its cold and after its well warmed up, not sure why. Charlie
Old Mar 11, 2006 | 10:44 AM
  #30
zerowick's Avatar
what kind of motor oil are you using Charlie? I have been very satisfied with Amsoil Formula 4-StrokeŽ Power Sports 0W-40 Synthetic Motor Oil. check it out.
