SP 500 HO Carb
Old Jan 8, 2006 | 05:14 PM
colmc's Avatar
Default SP 500 HO Carb
I bought a used 2001 500 HO and it has been running horrible so I pulled the carb out to give it a good cleaning. The problem is, almost all of the screw heads are stripped on the thing so I can't pull it apart to clean it. So, anybody have any ideas how to get it apart or a spare carb they want to sell?
Old Jan 8, 2006 | 06:36 PM
SPORTSMAN70003's Avatar
Visegrips or take a small grinding wheel and cut a slot in the heads and use a flat screwdriver.
Old Jan 8, 2006 | 07:13 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
if you can use any screwer driver to get a bite, try using an impack screwdriver. (the one you use a hammer with). the shock, vibration, will loosen it.
Old Jan 8, 2006 | 07:31 PM
colmc's Avatar
my problem is I can't get to the throttle plate in the carb and I don't really want to hit that with a hammer in case I bend the throttle shaft.
Old Jan 11, 2006 | 12:10 AM
colmc's Avatar
I'm afraid even the jets are stripped. Is there a good salvage yard anyone can suggest?
GregM
Mar 6, 2018 06:53 AM
GregM
Jul 29, 2015 09:41 PM
ghost civic
Jul 27, 2015 03:15 AM
Aitch
Jul 21, 2015 09:40 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
