clutch problems!!!!
Old Jan 9, 2006 | 12:14 PM
naterj's Avatar
Default clutch problems!!!!
I HAVE A 95 SPORTSMAN 400. AFTER PULLING A LOAD FOR ABOUT 1/2 HOUR, THE BELT BEGAN TO SLIP AND THE PVT COVER LATER MELTED. I REPLACED THE BELT AND THE COVER. WHEN I DID A TEST RUN I WOULD NOT TURN THE WHEELS AND THE BELT FELT LIKE IT WAS STILL SLIPPING. I PULLED THE SECONDARY OFF AND FOUND THE BUTTONS WERE IN PIECES. I REPLACED THE BUTTONS BUT THE PROBLEM IS STILL THERE. ANY IDEAS ON WHAT TO CHECK NEXT?
Old Jan 9, 2006 | 12:50 PM
conig's Avatar
how about the primarys buttons/bushings?
you may have gotten thewrong belt. have you pulled the cover off and reved the motor up in neutral to see if the belt is getting grabbed by the primary. also did you preload the secondary spring when you put the helix back in.
Old Jan 9, 2006 | 01:20 PM
naterj's Avatar
I DID PRELOAD. I HAVE NOT CHECKED THE BUTTONS IN THE PRIMARY AS I DONT HAVE THE TOOLS TO REMOVE IT AND I DIDNT KNOW THERE WERE BUTTONS IN THE PRIMARY.
Old Jan 9, 2006 | 02:32 PM
naterj's Avatar
its the right belt. it looks to be loose though. all but one shim have been removed from the secondary. should i try moving it at the engine mounts?
Old Jan 9, 2006 | 03:14 PM
conig's Avatar
i think that depends on whether or not the primary is moving. did you rev it in idle? does the belt move.
if the primary is moving but not grabbing the belt I would look at motor mounts. if its not moving then theres the problem and its probable time to rebuild the primary. or buy a new one/ used ebay.
Old Jan 9, 2006 | 03:26 PM
naterj's Avatar
it moves and the bike will drive but very bogged down and very slow.
Old Jan 9, 2006 | 04:56 PM
naterj's Avatar
ANYONE HAVE AN IDEA OF WHAT TO CHECK NEXT?
Old Jan 10, 2006 | 12:40 PM
conig's Avatar
if the primary is bad it will cause boggin problems. was the helix scratched up? if it had a large enough gouge to stop it from moving on the buttons this could be it.
Old Jan 10, 2006 | 01:20 PM
naterj's Avatar
YEA, CONTACT AREAS ON THE HELIX HAD DEEP SCRATCHES, YOU THINK THIS MIGHT BE IT THEN?
skinnyr6
Aug 25, 2023 02:18 AM
clsharky
Jul 13, 2015 02:07 PM
200es
Jul 10, 2015 09:09 AM
coolguy420
Jul 10, 2015 01:17 AM
Wnthunting
Jul 9, 2015 03:02 PM
