I have an oil question
Old Jan 9, 2006 | 11:15 PM
sportsmanryder's Avatar
Default Help
I have a 2000 sp 500 what oil can i run in it in the winter, besides the polaris oil, and also can i run tranny fluid, in the transmission insted of the polaris tranny fluid. Thanks
Old Jan 9, 2006 | 11:47 PM
redmtn's Avatar
Default Help
I just use the Polaris stuff. I don't want to kick myself if I screw something up. There are alot of very ATV smart people on this site. You might want to put on your title: I have an oil question? That way people don't just skip over your post. I seem to get alot more responses when I'm specific. Good luck.
Old Jan 10, 2006 | 03:11 AM
jimmypsp700's Avatar
Default I have an oil question
I use 0w40 Mobil 1 only ($5.49). Especially in the winter. No need for 4 stroke wet clutch high priced oil here.
http://www.wixfilters.com/filterlookup/atv.asp
-500 HO 4 stroke oil filter-Polaris #
Wix 51356
Purulator 14610
AC Delco PF 2057
You can use Amsoil Series 2000 Chaincase lube. It works GREAT as a substitute to the Polaris AGL fluid. that is the only susbtitute I know of , its not auto trans fluid although it is thin.
see below from another post...
"What you refer to as an automatic transmission is not. The Polaris has a belt driven "automatic" with a drive clutch (on the engine) and a driven clutch (on the input to the gearbox) and a belt in between. It is the gearbox that you are referring to. The gearbox does no gear shifting at all, other than when you switch from forward to reverse or to low. It is simply a transfer case of sorts that gets power from the clutch system to the rear wheels. It consists of a bunch of gears, sprockets and chains. The belt and 2 clutches do all the "gear shifting".
Do not use ATF in the gear box. There is nothing hydraulic about the gearbox. It requires a good quality synthetic gear lube. Personally, for the quantity required and the infrequent changes required, I use the synthetic offering from Polaris. Others here do use other products with no problems. I am sure someone will be kind enough to provide info on other products. My vote, us the Polaris stuff! -DJ "
Jim
Old Jan 10, 2006 | 01:33 PM
I completly understand how the drive train works on the polaris models. The reason why I refer it as a transmission, is because that is how Polaris states it in all there books and manuals. just thought you would want to know. Keep in mind my bike is 2000 the drive train is not like the newer models.
Old Jan 11, 2006 | 02:36 AM
Sorry I didn't mean to imply you don't know, just passing on info.
I didn't take into consideration the year of your machine and I have a 2000 model (Scrambler) and I think it takes other that the AGL fluid but its still not Auto Trans fluid such as in cars. It may be gearcase lube. I can't remember for sure and I don’t have the manuals with me.
Jim
Old Jan 11, 2006 | 07:03 PM
Thats one thing I like about the newer Polaris bikes, the gearcase is a hell of alot smaller than the older models, I must be pulling around an extra 25 pounds more that a newer 500 sp.
Old Jan 12, 2006 | 02:42 AM
My 2000 scr400 trans takes the PPS, Polaris Premium Synthetic gear case oil (11 oz./ 325 ml).
The 4x4 of the same model takes 27 or 32 oz., the manual contridicts itself.
My 2002 sp700 trans takes the AGL, which just went up to $14 a qt! [img]i/expressions/face-icon-small-disgusted.gif[/img][img]i/expressions/face-icon-small-confused.gif[/img]
Jim [img]i/expressions/face-icon-small-disgusted.gif[/img]
Old Jan 12, 2006 | 10:59 AM
cornbread2's Avatar
The same good synthetic motor oil you use in the engine works as good or better than the expensive Polaris stuff in your trans.
There is no need to pay Polaris a fortune for trans oil.
Old Jan 12, 2006 | 11:20 AM
scramblered's Avatar
you can use the same oil in all pvt polaris tranny as the same oil in the sleds use,it is actually a "chaincase" put into an atv.
amsoil,klotz,...
Old Jan 13, 2006 | 05:10 AM
I heard You can use Amsoil Series 2000 Chaincase lube.
It works GREAT as a substitute to the Polaris AGL fluid. But it is the only one i know of.
I know the trans in diff models and years use different fliuds!???? AGL, PPS etc.?? [img]i/expressions/face-icon-small-confused.gif[/img]
Any other insight, i know a lot of other fluids have been used by others APPARENTLY w/o problems, but i wonder.
Jim
EIF
Apr 20, 2017 07:15 PM
shimanok2
Jan 29, 2016 07:37 PM
Ahtatu
Sep 28, 2015 12:14 PM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
