cdi box for 03 pred ?
Old Jan 10, 2006 | 06:31 PM
tatertodd's Avatar
Default cdi box for 03 pred ?
ok I did the search but still uncertain on a cdi box.
I'm looking for more speed in second gear for flat trck racing.
sounds like the votex is good but maybe HPD might be better ?
Any help on this would greatley be appreaciated
Old Jan 10, 2006 | 06:40 PM
Webopper's Avatar
Not trying to talk you out of the CDI, but have you considered trying a sprocket change before droping the bucks on a CDI? I think that would be $20 worth investing there just to see if it got you where you wanted to be. Maybe a bit more than that if you do front and back, but not anywhere near the $300 or so for a CDI.
Just a thought...
Old Jan 10, 2006 | 08:29 PM
cr125predator's Avatar
I was wondering about a CDI box too. Thought about a sprocket change, but i really would rather get the CDI and not notice the gap in between the 4th and 5th gear so much. Plus i dont like how you have to shift so quickly out of the low gears.
Old Jan 11, 2006 | 09:29 AM
tatertodd's Avatar
didn't gine the sprocket change much thought but sounds alot easier on the wallet.
What tooth count do you recomend? I'm running stock gearing right now.
Old Jan 11, 2006 | 09:33 AM
tatertodd's Avatar
Hey cr125predator how does the radiator grill and scoops work? do they seem too help keep the fan from running so much?
Old Jan 11, 2006 | 08:57 PM
Well they do work, but it doesnt really help with the fan. the fans thermostat is set at a really low temp, so dont really worry about that, whether you have the scoops or not. I personally like and think it looks really nice. Its a bit pricey but i think its well worth the money. Here is the link to the grill & scoops Also check out the OMF scoops they're pretty nice.
Old Jan 12, 2006 | 06:32 PM
tatertodd's Avatar
thanks cr125predator that does look pretty cool .
Old Jan 12, 2006 | 06:56 PM
Webopper's Avatar
Ya know what, I'm not sure but I think you would want to raise the front up one tooth (15) and drop the back a couple (37 maybe). There was someone around that had a gearing chart for the predator, but I don't remember who it was...might try a google and see if that turns anything up...
Old Jan 12, 2006 | 07:00 PM
Webopper's Avatar
I should of looked first...here is the guy that had the gearing chart. Thanks there trailrider500.
Old Jan 14, 2006 | 09:37 AM
tatertodd's Avatar
thanks webopper that really helps,and thanks trailrider500 for doing the home work for evey one to see
Hankey Pankey
26
Oct 18, 2020 03:50 PM
BYC
Sep 25, 2015 02:10 PM
Hankey Pankey
Jul 31, 2015 05:50 PM
Hankey Pankey
Technical and How-To Articles
Jul 29, 2015 10:57 PM
95wolv
Jul 1, 2015 10:02 AM
