2004 Sportsman 700-mechanical
Old Jan 11, 2006 | 11:54 PM
prog's Avatar
Default 2004 Sportsman 700-mechanical
Hi there, I was hoping I could get some tech advice from you guys. Last weekend I was out with the kids at bragg creek and my quad just shut itself down after about 10 minutes of riding. It has fresh fuel, plugs, and has been serviced regularly. After about 30 seconds with the inginiton off, I could refire it and it would run for about another 10 minutes. Eventually I was able to get back to the truck. I have tried the throttle control adjustment but that does not seem to be the answer. Anyone have any thoughts on the problem.
Old Jan 12, 2006 | 12:00 AM
Polaridoo's Avatar
Bad fuel?
Maybe ignition system (coils, stator, cdi)?
Next time it is running bad or won't start pull the spark plug wire and test for spark.
Old Jan 13, 2006 | 01:47 AM
prog's Avatar
I am not sure how to check the spark when everything is dead ignition included when it stops. The display etc hs no power.
Old Jan 13, 2006 | 06:20 AM
tipo176's Avatar
Bad battery, ground strap or ign. switch?
SP
Old Jan 13, 2006 | 08:49 AM
Bobcet's Avatar
Bad CDI Call your dealer see if he will loan you one to try myn did [img]i/expressions/face-icon-small-disgusted.gif[/img]
Old Jan 13, 2006 | 09:24 PM
VAP1507's Avatar
I have a 03 700. If the display is dead you may have a main breaker going bad. If you let it stand with the key off for 10 min and the power comes back that could be it. The breaker is under the the front cover in a little black bag. Thier is two of them and I can't remember witch one it is good luck.
Jmuddin284
Jan 19, 2026 07:16 AM
COFatboy
May 2, 2020 12:06 AM
velcro7279
Aug 24, 2015 01:15 PM
bradco
Aug 21, 2015 08:11 PM
Stirling
Aug 9, 2015 01:49 PM
