broke a front axle BAD UPDATED!!!
Old Feb 4, 2006 | 12:41 PM
TJ700's Avatar
Default broke a front axle BAD UPDATED!!!
i CANNOT push the broken part out from the other side.
i removed the left front ce and its a dead end. in no way can i get this thing out.
this steel must be hard. i tried different speeds, with different drills, and tons of bits.
all it did was make a shiny spot.
i dont see this being an easy fix at all.
ill stick to ridiing in 3wd i guess.
so sad.
Old Feb 4, 2006 | 01:01 PM
2manytoys's Avatar
Why cant you take the front diff out and slpit the case. It realy is not all that hard just time consuming. I can tell you the easy way to do it. You dont even have to remove the radiator.
Old Feb 4, 2006 | 01:06 PM
dontgetbehindme's Avatar
so sad.
Can you make some close up pictures and post them on here so we may get an idea how to help you better?
Old Feb 4, 2006 | 08:05 PM
baxy's Avatar
find or borrow a slide hammer
look at the end of it you will see threads
find a nut that will fit on it
find someone who will weld the nut to the broken axle
use the slide hammer to pull it out
or like the fella said earlier remove the diff and split it apart
maybe it's tight cause the axle might have twisted a bit and is jambing it into the male splines
Old Feb 4, 2006 | 09:37 PM
  #15
TJ700's Avatar
the only thing thats in the diff is the splines. i have the u joint section in my hand.
its broke off flush with the diff.
im afraid of welding to it, dont wanna killl any seals inside the diff.
i dont see splitting the front diff making it any easier. the other side didnt go thru, im sure this side doesnt either.
im gonna have to weld to it, and chance ruiining something.
only way i see it comming out.
the piece in there is loose, but the retaining ring has it stuck in there, and i cant get vise grips, or a screwdriver or anything else on the end.
sucks to be me.
thanks for the options, but non have worked thus yet.
Old Feb 5, 2006 | 12:43 AM
  #16
IdahoVinnie's Avatar
Find someone with a MIG welder and a spraybottle of water. Weld a little, cool it off, and repeat 'till done. Nothing should be ruined.
Old Feb 5, 2006 | 10:52 AM
  #17
TJ700's Avatar
thats my thought.
hope it works.
Old Feb 5, 2006 | 11:09 AM
  #18
2manytoys's Avatar
I can almost guarantee that if you put heat to the broken shaft you are going to have to replace the seal. Why not just take the diff out. It is not that hard.
Old Feb 5, 2006 | 12:53 PM
  #19
TJ700's Avatar
how is the taking the diff out going to make it any easier?
i might be able to take it to a machine shop and have them put it on a press, but this splined shaft is hard as all get out.
the bushing that rides on the bearing(splined part) is solid in the middle. if i take it out, i still wont be able to access the diff from the other side.
any insight, please help. i might not be understanding your meanings.
thanks!
Old Feb 5, 2006 | 01:15 PM
  #20
baxy's Avatar
HMMMMMMM
new axle couple hundred dollars............ new axle seal $5
oh here is a crazy idea .................................................. ..............change the diff fluid at the same time
this thread is getting out of control
you need to make something happen and just fix it or give up quadding
I sure hope that everytime you break down your not going to spend a week considering what to do
sorry for being a dick but really these things happen when you run your quad hard thats life we all break down and just get er done and fix them
