broke a front axle BAD UPDATED!!!
Old Jan 11, 2006 | 11:57 PM
TJ700's Avatar
Default broke a front axle BAD
twisted the input shaft right off in the differential.
there is nothing to grab onto at all.
how shall i get it out to replace it?
ive got an old dummy shaft locked in for now, so i can ride in 3wheel drive if i need to.
im lost.
Old Jan 12, 2006 | 01:14 AM
Polaris500HO4x4's Avatar
Try a drill bit... drill a hole a large one and find a nice size allen wrench that will fit snug in the hole... jb weld the allen wrench in there and yank it out
Old Jan 12, 2006 | 01:21 AM
TJ700's Avatar
thanks for the advice, but its broken off pretty jagged.
ive tried to get it with 2 flat screwdrivers, and a set of vise grips.
there isnt a flat spot to drill. sucks to be me.
Old Jan 12, 2006 | 05:24 PM
Andre's Avatar
Grind a flat spot in the center of the shaft with a Dremal or grinder, then use a center punch to make a punch mark, then drill with a tiny drill bit and work your way up in bit sizes, then tap the hole for an eye bolt. Tie some wire to the eye bolt then tie the other end of the wire to the head of a three pound hammer, then swing away.
Old Jan 12, 2006 | 06:07 PM
BigDog800EFI's Avatar
If you still can drive in three wheel drive, are you sure your talking about the input shaft and not an axle. If its an axle take out the other side and pound it out from the other side with a brass rod. I reread your post. just take out the other side and pound it out
Old Jan 12, 2006 | 06:25 PM
TJ700's Avatar
the input shaft on the u joint end of the front axle, not the main shaft from the tranny.
there isnt any fluid in there, meaning its open from one side to the other?
thanks for the info, ill do just that.
thanks!
Old Jan 12, 2006 | 07:42 PM
MaineMudder3's Avatar
There is fluid but its encased in the housing. Take other the other axles and pound the broke piece out!
Old Jan 12, 2006 | 08:01 PM
TJ700's Avatar
too easy of a fix.
i was scratching my head wondering what to do.
Old Jan 12, 2006 | 11:04 PM
Thats why these sights are here. Someone has been there done that on almost everything.
Old Jan 13, 2006 | 12:14 AM
TJ700's Avatar
yea, bout the only one ive been too.
im into cars, boats, you name it.
i am registered on a ton of forums, and 99.9% of the time you ask a question, you are told to search, and its usually not in a nice way.
thanks for all the help!
