throttle response
Old Jan 16, 2006 | 12:41 AM
scrammersam's Avatar
Default throttle response
my throttle response is real crappy. what would be some causes of this.
Old Jan 16, 2006 | 12:48 AM
handycap's Avatar
Bad plug, bad gas, crap in carb, springs worn out on ft and rear clutches.
Jetting, needle position, not holding throttle wide open, to much oil in fuel, dirty air filter.
I love oil injection.
Old Jan 16, 2006 | 07:49 AM
ftwflh's Avatar
Not being clutched to the pipe will cause this too.
Old Jan 16, 2006 | 11:38 AM
scramblered's Avatar
too lean,too rich?
compression fade off...
what engagement that quad take off?
Old Jan 16, 2006 | 01:46 PM
after having the throttle on for a few secs it will then hook up. it seems to happen mostly on the bottom end. i have only noticed it since the engine was bored over for the second time now.
i donnt know if it is clutched of not it goes good when working but again since engine was done it has been ripping belts apart
Old Jan 16, 2006 | 04:43 PM
WIscrambler's Avatar
sounds like clutch alignment may be off. Also, you'll need a clutch kit to work best with that AAEN pipe.
Old Jan 16, 2006 | 04:52 PM
how do you check the alignment and how do i tell if it has been re clutched
Old Jan 16, 2006 | 05:08 PM
I believe the stock clutching is white primary and red secondary. Go to HPD's website for checking clutch alighment. It is in their tech tips section.
Old Jan 16, 2006 | 05:10 PM
do you know what could be causeing it to come out of alignment thanks
2quiker
Mar 22, 2022 08:36 PM
Customer Service #1
May 15, 2020 08:46 AM
hueby
Nov 6, 2015 11:34 AM
Nosniborpapa
Sep 12, 2015 05:54 PM
MeadowlarkFarm
Sep 9, 2015 03:08 AM
