compression low on trail boss
Old Jan 18, 2006 | 10:30 PM
polaristb250's Avatar
Default compression low on trail boss
my trail boss 250 will notstart and it has a brand new starter and bendix, i have about 60psi of compression. is that to low for my qaud to start? what should the psi be around? and also if this is the problem, what do i need ot do to raise the compression?
I NEED HELP BADLY!!!!!
thanks,
alex
Old Jan 18, 2006 | 11:08 PM
2manytoys's Avatar
The compression s way too low. It needs to be around 120psi to run good but no lower than 100psi to run at all. You need a rebuild. Simple to do and cheap. All you need is rings and a small bore job.
Old Jan 19, 2006 | 01:06 PM
hey thanks alot how much am i looking at spending?
Old Jan 20, 2006 | 04:03 AM
Tyayo420batavia's Avatar
200-300 if you do it yourself a lil more at the shop
manuelrivera
Aug 8, 2015 04:34 PM
Backwoods_badass
Aug 2, 2015 10:40 PM
Backwoods_badass
Aug 1, 2015 10:25 PM
southbayman
Jul 24, 2015 09:30 AM
Gnuters
Jul 19, 2015 10:03 AM
