fluid in tires
Old Jan 20, 2006 | 03:26 PM
UTU's Avatar
UTU
Default fluid in tires
you ever get a bucket of water and move it in a circle up & down real fast (:> This is what the fluid will do and talk about tires outa balance and jumping around (:< Still this will only happen when you go fast (:> Not that we run fast (:>
Old Jan 20, 2006 | 05:09 PM
Andre's Avatar
How about loading the back rack with some weight to counterbalance the weight of the plow. I know the IRS will squat a little bit, but adding weight to the rack is cheap, easy and removable. It works for all the plow trucks out in this neck of the woods.
Old Jan 20, 2006 | 05:20 PM
spyder6's Avatar
Originally posted by: Mutley
Thanks for the replys! I have tried it in both 2&4 Wheel Drive! It just won't back up the hill
going forward it goes right up. This is a 2006 machine and I like it .I have plowed snow before
so that is not going to be a problem I use a Skid Steer when it gets deep got this new atv and it hasn't snowed yet.might check on some different tires.
thanks
mutley
you are aware that to use 4x4 in reverse you must hit the reverse overide button, arnt you?
Old Jan 20, 2006 | 09:58 PM
ESCAVADER's Avatar
My new KUBOTA tractor came with a new beet juice formula,that doesnt freeze,and wont rust your rims.I have never heard of any body doing an ATV,but i dont see why it wont work for low ground speeds.There have been a few times i wish my MAGNUM was loaded,might have kept me from being up side down. Fill only 2/3 full max,they sell the adapter kit right at NAPA.
ESCAVADER
Old Jan 21, 2006 | 12:57 AM
  #15
2000scrammy's Avatar
Spyder6 is exactly right. The polaris 4x4 will only be in 2wd when in reverse even if u have 4x4 on unless you push and hold the reverse override button. Then as soon as the rear tires start to spin it will engage the front wheels.
Old Jan 21, 2006 | 03:05 AM
  #16
itstillruns's Avatar
to fix the going backwards in 4x4 thing for good ,go to quadovator.com he'll hook ya up with some nice stuff that works!
Old Jan 21, 2006 | 05:37 AM
  #17
Mutley's Avatar
[img]i/expressions/face-icon-small-smile.gif[/img]
Thanks for the information about the override button I guess I should have read my book..
mutley
Old Jan 21, 2006 | 06:45 PM
  #18
Elprebse's Avatar
Quite funny to read this thread about fluids in tires.
Polaris' engineers spent hundreds of thousands if not millions setting up your ATV to be (among) the best in the industry.
And then a couple of rednecks like us (not an offense - myself included), are discussing if "we should fill the tires with water" for better traction?
Ofcourse there's always room for smaller or larger hi-tech improvements, as the manufacturer also has to sell accessories and keep the cost down on the stock machines, but if fluid was meant to be in the tires, I think that there something the tire manufacturer's engineers have missed for years. Just a thought...
JackTheKing
Sport Quads
Nov 4, 2019 06:06 AM
bmark0610
Sep 7, 2015 09:42 PM
Jason Campbell
Sep 7, 2015 02:25 PM
twon1235
Utility ATVs
Sep 7, 2015 04:38 AM
black_thunder
Sep 7, 2015 01:24 AM
