Does the 39 PWK carb kill gas mileage?
Originally posted by: 16polaris
Thats the whole point, The bigger the carb the more fuel it's gonna use, just like a 2 barrel carb and a 4 barrel carb.
#15
#16
At this point, I usually say thanks for all the replies, but not all the replies were helpful. I know it will take XXX amount of fuel to run with my mods if I have a 27mm carb or a 483902 mm carb. I'm under the impression that fuel mileage will only slightly decrease to compensate for the additional power that the 39 PWK carb will offer.
#17
Thats not what he said, if you read it correctly he is adding an HPD trail pipe, bubba porting, lighter flywheel, sounds to me like the mods are there.
#18
#19
gunman457,
Your carb doesn't make power like you think. It helps make your mod's work better. It allows more air and fuel you need to forfill your mod's needs.
But you stated above that it doesn't deliver more fuel, now your saying it does, when are you gonna get your so called "facts" straight?
#20
Originally posted by: gunman457
Like I said before, a bigger carb won't kill your gas mileage, but BIGGER JET"S and any other engine and exhaust mod's will. If anything, it will let it breath easier.
just FYI with a pipe and a stock cylinder I ran some drag races against a friend I run 5 times before making a change and 5 times after getting the PWK on and jetting it. each time I would loose by more. the bike is definatly more responsive and felt faster but it just wasn't in these races.
however once I ported the PWK was a neccasity as I could not keep the mikuni's bowl full on fuel no matter what I did.
