polaris 500 reminton????
Old Feb 1, 2006 | 03:20 PM
brownweiser's Avatar
Default polaris 500 reminton????
now that i bought this machine what can i expect? how often should i do the matinance? any other info on this atv would be appriciated thanks
Old Feb 1, 2006 | 03:22 PM
colt2245p's Avatar
i would suggest you change all fluids front and rear diffs also grease it thoroughly dont forget the ones on the front prop shaft and then ride it
Old Feb 1, 2006 | 04:09 PM
thanks for info colt
Old Feb 1, 2006 | 07:51 PM
floodrunner's Avatar
That’s good advice. As you’re going through the fluid changes it’ll give you a chance to look around for damage / wear. Grab hold of the hubs and suspension parts while it’s up off the ground and the wheels are off. Pull ‘em and twist ‘em to see where you have movement. That’ll indicate worn bushings or bearings.
Lube frequency depends on the conditions you ride in. If you go through a lot of deep water you should lube it more often. My rule of thumb is, if you shoot grease in and no water squirts out of the joint, it probably didn’t need to be greased. If you get water out it did. With a little experimentation on your part after each ride you should be able to come up with a pattern for required maintenance.
Old Feb 2, 2006 | 11:30 AM
thanks for info colt and floodrunner
Cole Hadden
Jun 15, 2025 09:05 AM
Ramman1
Aug 11, 2022 01:53 PM
NoJoke
Aug 9, 2015 12:39 PM
Polaris Side by Sides
Jul 30, 2015 12:14 PM
maxjung
Jul 13, 2015 05:11 PM
