reverse limiter 93 trailboss 250
Old Feb 1, 2006 | 05:26 PM
drlang's Avatar
Default reverse limiter 93 trailboss 250
Finally getting this thing put back together, it seems to idle like on the limiter. It clears up when off Idle, and the etc switch is not depressed. I'm assuming the reverse limiter is the culprit. I've seen different threads with conflicting fixes. Is it the box with 4 wires, or is it the box with 3 wires? Then what do I do? It also Idles ok with the reverse button pushed. I've read that you cut the black wire, but am unclear. After confirming it's the reverse limiter box I will be buying a new one, the kids will be riding this thing. Also it is a 2x4
Thanks, Doc
Old Feb 1, 2006 | 07:09 PM
2Stroke400Scrambler's Avatar
Hey .. i have a trail boss 250, i sorta noticed my bike does that too, it revs up and back down i tried settin the idlein up but nothing, i never tried the reverse button. hopefully somebody will give u some info so i can get sum info on it and fix mine too
Old Feb 1, 2006 | 07:18 PM
ftwflh's Avatar
It is the box with 3 wires.Follow the wires back to the connection block and unplag the black wire this will disable the unit.
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
r1pilot83
Sep 27, 2015 07:38 PM
Steeldon
Sep 9, 2015 09:38 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
